Installing an Arc fault Breaker
| Posted in Energy, Heating & Insulation on October 26, 2004 05:45am
Hi guys,
I had a service panel upgrade and now I need to install an Arc Fault breaker for my bedroom receptacle circuit. It sounds pretty straight forward. The existing circuit, which I assume to be in good shape, is protected at the panel by a 15 amp breaker. Can I just swap out the regular breaker for an Arc Fault breaker, tie in the extra pig tail on the arc fault breaker to the neutral bar and be done with it? Or am I missing something?
  1. andrewh | Oct 26, 2004 06:29am | #1
    Roughcut,
    Also disconnect the circuit neutral from the bus bar and onto the secong terminal on the AFCI. That should be it.
    Andrew
    1. jdmover | Oct 26, 2004 06:32am | #2
FHB Podcast Segment: Embodied Greenhouse Gas Emissions and the Building Codes
