Installing brickmold on concrete block
rbarre | Posted in Construction Techniques on January 19, 2021 12:24pm
I’m installing a Pella double hung vinyl window into a concrete block opening in the foundation. The old window suffered a rotted threshold after 60 years, and was installed without wood bucks. I need to place brickmold around the window onto the concrete block. What and how would you suggest to fasten the brickmold? I thought of drilling pilot holes and pounding cut nails into the holes. Is there a better way?
  1. mikeys | Jan 19, 2021 12:56pm | #1
    simpson strong-tie titen 3/16in. x ?in. phillips flat-head concrete and masonry screw
    1. rbarre | Jan 20, 2021 10:01am | #3
      I was trying to avoid the rather large hole to fill on the brickmold. But it may be the better way. Thanks for the response.
  2. florida | Jan 19, 2021 07:35pm | #2
    I'd also use PVC brickmold.
    1. rbarre | Jan 20, 2021 10:02am | #4
      Yes, PVC all the way. Thanks.
        2sheps | Jan 20, 2021 10:45am | #5
        I'd be tempted to stick it on with white polyurethane caulking. If you can hold it in place for a day, it would likely stay in place for decades. Perhaps there's an area where you could use a few small nails into the window frame or flange.
