Installing cedar shingles
fuzzzy | Posted in Construction Techniques on June 14, 2005 01:32am
Hello, I have a job to install cedar shingle siding. Is it acceptable to nail directly over Tyvek? I’ve heard of this breathable mesh, but that may be just on roofing applications. I was planning on dipping the shingles, and using stainless steel staples with a 5.5″ reveal. Any thoughts? Thanks.
  1. woodguy99 | Jun 14, 2005 01:47pm | #1
    Fazz, welcome to Breaktime!
    Nailing directly over Tyvek in some cases has led to deterioration of the Tyvek.  You'd be smart to use the breathable mesh, I forget the name, but it's much thinner than the CedarBreather used on roofs.  Another option would be to use tar paper instead of Tyvek--it works just as well as Tyvek, without the deterioration issues.
    I like to use nails for shingles, because it allows them to expand and contract a bit more and because they're easier to remove when you need to do a repair.  I've seen galvanized staples rust through after a few years, but you would do fine with SS staples.
    Finally, if I were you I wouldn't spend any time dipping my own shingles when you can by them pre-dipped.  Maibec is the industry leader in the northeast, but Fraiser makes an excellent product at a better price.
    If you do a search of this site for cedar shingles you'll find countless discussions on this topic.  Give it a try!
    Mike
  2. fingers | Jun 14, 2005 06:08pm | #2
    What Mike said.  They will be a pain to dip, and a pain to replace if fastened with staples.  Go with pre-dipped and ss nails.
    The mesh product you seek is Home Slicker by Benjamin Obdyke  http://www.benjaminobdyke.com .  It's kind of pricey.  I might just go with building felt.
    Good luck.
    Edited 6/14/2005 11:14 am ET by fingers
