I wil be installing a floating cork floor for a customer. I just picked up the material today,assumed it would install like any other floating floor. The instructions are suggesting you use a cork tapping block,I assummed i could use the one i have for laminate floors?
Anyone know the difference between the two blocks? I don’t want to damage the floor using the wrong tools,but will use the laminate block if it works.
Anyone have any experience with this?
Greetings ad,
This post, in response to your question, will bump the thread through the 'recent discussion' listing again.
Perhaps it will catch someone's attention that can help you with advice.
Cheers
when in doubt add garlic
I've installed cork floors 1'x3' with just 2x4 blocks. Always tap on tongue only. Follow instructions provided. After first cople of rows you can fly. Easy install. Good luck,Steevie
bumpwhen in doubt add garlic
