Installing drywall cove moulding
Biff_Loman | Posted in Construction Techniques on November 2, 2007 04:12am
Seeing as I’m laid off, I’m doing some handy stuff for family and friends.
I’ll be installing some drywall cove moulding, which I’ve never done before. I guess drywall screws will work fine. I’ll probably use just a few of those with a lot of liquid nails.
Any words of wisdom?
Edited 11/1/2007 9:17 pm ET by Biff_Loman
  1. Biff_Loman | Nov 02, 2007 05:06pm | #1
    I guess it's pretty much self-explanatory, then. . . ?
    What would you say is the best method of cutting it? I'm not sure if I should just have at it with a drywall saw and then mud the joint. Intuitively, it seems that would work.
  2. DougU | Nov 02, 2007 05:45pm | #2
    Maybe I dont  get out enough but what is drywall cove moulding?
    got a link?
    1. Biff_Loman | Nov 02, 2007 07:11pm | #3
      It's just pre-formed 1/4" drywall crown mould, in the form of a large cove - something like 4 or 5 inch radius.It's similar to the run-in-place plaster cove mould I have in my house, built in the '60s. Anyways, it seems 90% easier than run-in-place.
      Edited 11/2/2007 12:12 pm ET by Biff_Loman
  3. BUIC | Nov 02, 2007 08:19pm | #4
      1. Is the cove foam, plastic, or wood?
      2. Are the walls plaster or rock?
      3. You want fries with that?  ;>)
      buic
    1. Biff_Loman | Nov 03, 2007 12:27am | #5
      None of the above. It's actually drywall, 1/4". Is this not a regular product?Walls are plaster.
      Edited 11/2/2007 5:28 pm ET by Biff_Loman
      1. BUIC | Nov 03, 2007 06:51am | #8
          I haven't worked with drywall molding, but joint compound and finish nails with a nail gun would be my first try.
           Have you tried to call the manufacturer?
          Sorry can't be more help...buic
  4. brucet9 | Nov 03, 2007 01:18am | #6
    Astonishingly enough, at least one manufacturer seems to recommend just sticking the cove up with drywall mud and maybe a couple of nails beneath the bottom edge for support until it dries.
    http://www.bpb-na.com/us/english/cove_and_cornice/downloads/ceilingdecor_installation.pdf
    BruceT
    1. Biff_Loman | Nov 03, 2007 04:51am | #7
      And they seem to want me to miter inside corners. Nice.I think I'll try hot-glue + liquid nails or whatever. Should work well.
Picture-Perfect Pergola
