installing edge blocking for drywall
pulper_11 | Posted in Construction Techniques on December 6, 2021 03:30pm
Hello – When i demo’d my bathroom, i took out blocking around the edge of one wall.  Now I’m trying to put some back in for the drywall (or strapping) to attach to.
I’ve come across an area that is too narrow to fit in a 2×4 or 2×6.  it’s underneath the DWV that i installed (see pictures).
Any suggestions as to how to handle this narrow area?  with the drywall or strapping screwed every 16″, the thickest board i would be able to fit is about 1/2 or maybe 3/4″.
thanks.
  1. florida | Dec 06, 2021 03:42pm | #1
    Sure, use a 2 X 6 there above the pipe and attach a ripper the same height as the pipe to the outside edge of it.
    1. pulper_11 | Dec 06, 2021 07:02pm | #2
      Thanks Florida for the comment. However, I'm not sure what a ripper is.
      1. florida | Dec 08, 2021 09:26am | #4
        In your case a ripper is a piece of 2x wood ripped to the height of the pipe so the bottom is flush with the other blocking
  2. mikemahan3 | Dec 07, 2021 01:34pm | #3
    Attach a 2x4 from the edge of the existing block to the top plate of the. intersecting wall.
  3. pulper_11 | Dec 18, 2021 12:47pm | #5
    sorry for being late getting back here. i appreciate all the help. what i ended up doing was notching out a 2x4 so that it would fit the area under the pipe. a friend of mine suggested this and it worked well. i attached a couple of pics.
FHB Podcast Segment: Sometimes Spray Foam Makes Sense, Sometimes It Doesn't
Spray foam is a great invention, but it's not always necessary.
