Anybody got a slick way to lower 8″ terracotta flue liners down an existing brick chimney.Old timer told about rig he saw that was two hinged bars that had lil legs on the bottom to catch bottom of tile.When the tile was lowered down and in place; theyd slide a section of pipe or something down the rope and it would slide over the bars contracting them so you could remove the rig.Thers not a helluva lot of clearance room around the outside tile once its in the flue.Any ideas?
i use two pieces of stove pipe wire looped through the tile opposite each other plus length of drop
let pipe down then cut wires.
done this a number of times to get around rebricking chimneys
to break out old rotten flues use steel bar approx 20 lbs & weld chain link on end & attach rope
take out pieces at clean out (ps steel bar has chisel type end)
The breakout wya I heard about involved using the long rod with the link welded on - then chuck it up in a Hole Hawg.Steelkilt Lives!
Hinge two 2' lengths of 2x4 together with the butt hinge at the top. Bevel the bottoms of them to a sharp point. I'm not sure what the type of hinge is, but it has two long legs and locks when the two legs are aligned with each other. Most hardware stores have them. Install this hinge so the spread of the bottom of the bottom of the 2x4s is slightly wider than the interior of the flue tile. Slide the tile over this mechanism. Attach a rope to the top and one to the center of the hinge that we don't know what its called. Drop the rope to the hinge down the chimney. Butter the top of your tile with fireclay. Slowly lower the tile in place. The bevels on the 2x4s guide the tile into place. Pull the rope on the hinge, which releases the tension and pull your flue tile setter back up. Repeat.
Edited 7/17/2003 6:53:47 AM ET by greencu
Why not just use a good stainless liner? My understanding (although I don't know if it's just a story) is that clay flue liners do not meet current flue liner heat performance specs, but they're a "grandfathered" material being so commonly used.
_______________________
10 .... I have laid the foundation like an expert builder. Now others are building on it. But whoever is building on this foundation must be very careful.
11 For no one can lay any other foundation than the one we already have--Jesus Christ.
1 Corinthians 3:10-11
If he's relining for a fireplace, its often hard to get the proper size stainless liner into the existing chimney. Connection at the top of the smoke chamber is also difficult. For a controlled combustion unit, your right on target.
