I have access to some left-over 4×8 sheets of pink insulation board that I would like to insulate a metal building with.
What would be the best and quickest way to attach them to the walls and ceiling? Something like Liquid Nails or what?
I did the same thing for a friend who had a steel out building and we got a box of self-tapping screws and some plastic washers, Like the kind the roofing guns use to wind lock tar paper and put it up just like SR. Worked great --do it in any type of weather and don't have to deal with dirt, rust etc on the steel ribs.
Just as a side note--some places frown on foam board being uncovered for fire reasons but in a storage building that is unattached they may not mind, Hope this helps , mike
Sounds like a lot of holes in the roof which is 22x50.
Oz ---I see what you mean about the roof but I was invising corragated sheets over struts or purlins and a side wall frame with some sort of stud work. Guess it is one of those "gotta see it " Well that was the situation and my buddies steel out building so that I guess the minds eye don't apply to yours. Mike
PL300 is the adhesive for foamboard, it is probably sticky enough to hold the stuff to the walls w/o fasteners. The ceiling may take some more creative solution.
I was thinking about trying water based contact cement.
That could work, PL300 may also work on the ceiling w/o fasteners or bracing, give it a try first on one sheet.
it will hld it but you may experice some sag making things uneven
WOW!!! What a Ride!
With relatively roughness of the surface of the foam I don't think that contact cement will hold very well.I would use one of the pannel ahesive/construction adhesvies that are OK with foam.IIRC I used PL Preminum. But check the label I that may not be the right one.Also I would check to see if the metal has and oils on it from manufacturing.
Thanks for all the replies.
It's an all metal 30 X 50 building. I could put up furring strips and such. But that seems right a lot of work if the PL-300 does the job.
Building is 20 years old and all the oil seems to be gone. So it's not like I have to get it right the first time. I'll do a little experimenting as I go. I'll try the PL-300 on a couple of pieces and if it works I'll go on. If not, I'll try something else. Ceiling will be the hard part.
PL 300 is the right one for foam but I don't know the set time for it - on a cieling that could be a challenge. How long you want to stand there holding it up while the glue kicks???Im tinking of Enerfoam. Spray urethene foam out of a gun, compare one can of it to about twenty tubes of caulk style. Sets up quick. very sticky
But again, I don't know about long term - you could have a lot of thermal expansion in the metal roof that might break the bond over time. Maybe contact the company for specs and answers. They decveloped it originally for a sheet rock glue on cielings and walls.
Urethane foam or RTV silicone both work well. I'd personally go with the first one.
WSJ
OK, Now we have to figure out what to do about the colour. paint the pink foam or start driving a pink pickup truck and wearing lipstick?
