Installing Pre-finished stair treads
Steve B | Posted in Construction Techniques on December 14, 2008 06:45am
Stair treads:
Just looking for some other alternative means of secuing pre-finished stair treads down.  Currently I drill and counterbore for a 3/8″ plug after I use a #10 screw to  secure the tread down to the stringer.  This always leaves a hole that must be plugged and then stainend and finished to match the pre-finish color.  I have also used a #8 trim head screw, which reduces the size of the hole to 1/4″.
If anyone has any advice or help please reply.
Steve
  1. calvin | Dec 14, 2008 06:56pm | #1
    Pocket screws and PL Premium from below .  If the area is open below, much easier.  If not open, still possible with a little thought and manuevering.
    http://www.quittintime.com/
      Steve B | Dec 14, 2008 06:59pm | #2
      Thanks Calvin, yes Ive used pocket screws in the past, but this stairway is not open from below and the tread is only a 10-1/2" making it impossible to reach underneath.
      The center row of screws will be covered by carpet, but the two outsice rows will be visibe.
