installing puck lights w/ transformer
Grantdawg | Posted in General Discussion on April 9, 2008 11:12am
Having trouble figuring out how to install puck lights that require a separate transformer–they’ll be in a built-in bookcase and will be controlled by a wall switch. The lighting supply house sold me the transformer, but it has one set of terminals for lights, and I have six to install–of course the instructions are totally unclear, but assuming I need a separate device to connect to the transformer that has enough terminals for all of the light?
Also, the instructions say that the wires should be run in tracks instead of just stapled/secured to the cabinet–is this necessary? Do the wires themselves get that hot or is this to protect them from getting nicked/poked?
Thanks for any tips!
    IMERC | Apr 09, 2008 11:24pm | #1
    they'll be in a built-in bookcase and will be controlled by a wall switch.
    do you intend to switch the lights or the transformer???
    sugest you switch the transformer...
    but it has one set of terminals for lights, and I have six to install--
    wire the lights one to the other in parralell....
    nothing unusual about that...
    what device would that be???
    two are enough...
    the instructions say that the wires should be run in tracks instead of just stapled/secured to the cabinet--is this necessary?
    using the right style of track makes the job look so much more professional...
    no...
    yup...
    WOW!!! What a Ride!
    1. Grantdawg | Apr 09, 2008 11:48pm | #2
      Thanks for the info--wiring the lights in a string makes total sense--just had it in my head that all of the lights would be wired to the transformer, so thought I'd need a separate unit with enough terminals.
      Thanks again!
        IMERC | Apr 09, 2008 11:58pm | #3
        you can still do that with two terminals...
        just gang the wires....
        IMERC | Apr 10, 2008 12:00am | #4
        if you don't want to string the lights together go to Radio Shack and get a bus bar to give you individual screws for each light...
  • Townhouse Transformation
