Installing Shower Surround
TomT226 | Posted in Construction Techniques on July 2, 2006 01:44am
Got a Sterling #72120100 48″ shower surround and receptor to install, and have a question of anyone that has experience with one of these.
The surround walls set on a flange in the receptor.  The directions say “Wall surrounds must rest within 1/32″ (the thickness of a credit card) from the receptor to ensure proper water management and to prevent leakage.”  This unit is going in a mobile home, so I’m worndering if it would’t be a good idea to run a bead of silicone all around the bottom, and set it directly on the flange so if the floor moves, it will continue to have a good seal.  The directions say to put a 1/4″ bead 4″ long near the front to compensate for out-of-plumb walls.
Silicone, or follow directions?
  1. Danno | Jul 02, 2006 03:44pm | #1
    For what it's worth, I'm with you. Not sure whether I would use silicone or Lexel, but something, IMO, would be better than nothing for the reasons you mentioned.
    1. TomT226 | Jul 02, 2006 11:54pm | #2
      Thanks for the reply.  I'm gonna holler at Sterling/Kohler tomorrow and see what they say.  For what it's worth, I'll post what they reccomend for other people that may need the same solution.
    tfarwell | Jul 03, 2006 05:58am | #3
    I have installed a couple of the Sterling units - been very happy with the results.
    I would not put silicone all the way around, but just in the last foour inches as indicated. That flange area acts as a "gutter" to allow any water that gets into the vertical seams to drain out. The directions say it needs to be 1/32 or less, but if you look at the flange, it goes up about a 1/2 inch. I would think if the floor flexed, it would have go a long way to cause trouble.
    You could consider putting a piece of plywood down where the shower is going to go to stabilize the floor. You would then need to trim out the front of the plywood.
    1. Danno | Jul 03, 2006 02:04pm | #7
      I've changed my mind--what ttfweb and DanH posted makes since--don't want to block the exit for the water from the vertical seams. They are right.
  3. DanH | Jul 03, 2006 06:20am | #4
    Yeah, never used this brand, but other surround systems I've seen are designed to shed water mechanically (like flashing). Caulk in the wrong place could actually dam in water and cause a leak.
    I'd at least think twice about this.
    1. edwardh1 | Jul 03, 2006 01:54pm | #5
      what is a surround system?
      the walls of a one piece shower stall, installed on a "base" to allow you to get the new shower into room without tearing out the door to the room???
      1. DanH | Jul 03, 2006 02:04pm | #6
        Yeah, a "surround system" is any sort of knocked-down shower surround. Sometimes in two pieces, usually in four.
    JeffBuck | Jul 05, 2006 02:09am | #8
    " or follow directions?"
    Uhhh ...... ?
    remember back in school when they said there's no such thing as a dumb question ...
    they lied.
        Buck Construction
     Artistry In Carpentry
         Pittsburgh Pa
