I have built a timberframe, enclosed it with SIP’s and plan to finish the exterior with pine board and batten. I am using Andersen windows. I was planning on installing the windows proud of the SIP’s by 1 3/4″ (3/4” strapping and 1” pine boards) to allow the battens and trim to be flush with the windows. Another carpenter said they install the windows so that the boards are flush and simply let the battens fall where they may (they don’t install any additional trim around the windows). What are the options for installing windows with board and batten siding?
The LevelSafe Pro automatically adjusts to uneven surfaces, making it easier and safer to work with extension ladders on sloped terrain.
Builder’s Advocate: An Interview With ViewrailRelated Stories
I have built a timberframe, enclosed it with SIPs and plan to finish the exterior with pine board and batten. I am using Andersen windows. I was planning on installing the windows proud of the SIPs by 1 3/4" (3/4 strapping and 1 pine boards) to allow the battens and trim to be flush with the windows. Another carpenter said they install the windows so that the boards are flush and simply let the battens fall where they may (they dont install any additional trim around the windows). What are the options for installing windows with board and batten siding?
