Installing Wood Floor on Concrete
fairban9 | Posted in Construction Techniques on September 11, 2006 07:59am
I am currently removing an old wood floor from an old house and putting it in my new house.  I have two concerns with how to install the new floor.  My house is a slab on grade and I’m assuming there isn’t a vapor barrier below the slab.  This makes me a little leary of installing the wood right on the slab cause I’ve seen what can happen in that case and I don’t want cupped floors.  The other concern is that I’ve broken some of the tongues a little bit and I’m wondering if there is a way to still install these without always worrying if it’s going to move.  I was thinking about just placing a vapor barrier or sound deadener on top of the slab and just glueing the wood together but I would like to know if there’s a better option out there.
Thanks to anyone who can help.
  1. huddledmass | Sep 12, 2006 09:23am | #1
    even if there was a vapour barrier under the slab thee would still be moisture coming from the concrete which would affect the wood.  If you are gluing this floor together i wonder if you need glue made by this company http://www.robertsconsolidated.com/index.cfm?fuseaction=dsp_content&subaction=dsp_dist
    apparently they make glue that moves or stays flexible with the wood..  also maybe you need tar paper under the floor with overlapped seams etc..
    "I hate quotations.  Tell me what you know"  Ralph Waldo Emerson
  2. ditch | Sep 12, 2006 04:41pm | #2
    fairban,
    I don't know why people try to salvage and re-install strip flooring, especially to install it in a new house..... unless it is wide plank antique... your time must be worth so little, I can't imagine how the trouble can be worth it....anyway...
    The only method used install 3/4 solid strip or plank flooring over concrete is by installing  plywood subfloor over a 5 mil plastic vapor barrier. The plywood needs to be ripped to 16" widths and installed 4" on ctr. with a pnuematic concrete nailer.  There are many variations of the plywood subfloor. Some contractors use 3/4" some use 2 sheets of 1/2" or 3/8". There are just as many ways to install a vapor barrier. Some glue the the ply with mastic in addition to nailing. Either way expect elevation issues.
    IMO, solid wood flooring shouldn't be installed on a slab...there is just too much potential for failure.
    Once the tongues/grooves are broken the flooring is no longer servicable. All the old dirt and finish needs to be cleaned from the t&g's or the floor won't fit together properly. The tounges have been stressed during removal so the likelyhood of breaking them increases during re-installation.
    Suggesting "glueing" the floor together and floating it over the slab indicates a lack of knowledge pertaining to wood floors and "water and wood". What your asking  of this used flooring would be a challenge for even the most seasoned wood floor pro.
    1. dfkirk | Sep 12, 2006 04:49pm | #3
      Havn't you ever heard of a 'floating floor'?
      1. ditch | Sep 12, 2006 06:45pm | #4
        I'm gonna assume that you are either joking... or have no idea what the definiion of "floating floor" is.
