insulated panel 4 (ext.)med lab box
Chipper | Posted in General Discussion on February 6, 2004 06:47am
any advice on where I can find / order / purchase (preferrably web-site) a thermal insulating panel for a medical lab box that is wall mounted on the exterior of a medical center.  I mounted 2 steel boxxes to a brick masonry wall with a power driven masonry gun. 1-1/2″ nails with washers.  I have to replace the back insulated panel on both boxxes.  The consistency of the original panel, before being damaged, was a very dense sort of styrofoam?  was approx. 1/2″ inch thick X 12″  X  12″.   The panel must protect the contents in the box from moisture, extreme heat & extreme cold.
Any help is greatly appreciated!                  Thank You!                         Chipper      2/5/04
  1. 4Lorn2 | Feb 06, 2004 07:32am | #1
    If you could more fully explain what your asking for, a picture or two would be ideal, I think I could picture what your talking about.
    From the mental picture I have I suppose some 1/2", you could go with any standard thickness, generally by 1/2" increment, to 4" isocyanurate foil faced panel. These are relatively cheap, easy to work with and sold in 4x8' panels. These have a slightly higher R-value over styrene foams.
      IMERC | Feb 06, 2004 07:46am | #2
      Old style insulated milk drop box sortta type thing...???
      1. Chipper | Feb 07, 2004 12:49am | #3
        yes!    any tips?
          IMERC | Feb 07, 2004 12:57am | #4
          I would have designed one and had it fabbed up at the sheet metal shop...
