insulating a crawl space : foil face up or down , no foil , I am not sure
Deckorators Voyage decking, which is mineral-based rather than made of a plastic or wood composite, is lightweight and doesn't expand and contract as much as standard composite decking.
Vapor barrier goes on the warm side in most climates.
I'm not a expert on this subject matter, so I would refer you to a much better reference:
http://www.buildingscience.com
Search "crawlspace" and you'll find several articles on the subject matter. The short version is they advocate bringing the crawlspace into the building envelope and sealing the floor of the crawlspace. If you like it vented, I think that you want no vapor barrier and sufficient permeability to allow the building to dry to the inside. If you include a vapor barrier, you are providing a condensing surface that will increase the crawlspace moisture content. The degree to which this is a problem depends upon your climate
