Insulating a roof
beartrouble | Posted in Energy, Heating & Insulation on August 7, 2006 05:30am
I am self-building a 20×22 workshop. Half the roof is a 14in12 gable; the other half is a 7in12 shed. According to the code tables, all I require is 2×6 24oc for both. However, with allowance for venting, 2×6 rafters will not even give me the R20 that 2×6 walls could. QUESTION: what is the most efficient way to increase the depth of insulation on both roofs?
– Go 2×10 for all rafters?
– Fur out the inside (outside?) with 2×4 utility lumber?
-Sheath the inside (outside?) with rigid foam?
I live in mid-northern Canada and although good old global warming means it is unlikely we will ever see a bitter -40 for weeks at a time again, I still want to minimize my gas bill.
  1. joeh | Aug 07, 2006 05:39am | #1
    It's a shop? Why would you want to vent the roof?
    What kind of snow load are you designing too?
    2x6@24" sounds kinda shakey to me.
    Go with 2x10s & blow it with dense pack cells & you'll be toasty  plus as an added bonus it won't collapse some day when Global Warming decides to dump 3' of wet snow on it.
    Joe H
    1. beartrouble | Aug 07, 2006 06:39am | #2
      Snow load is 40PSF. I thought under sheathing vetilation was an absolute requirement regardlass of purpose.
      1. Piffin | Aug 08, 2006 01:33am | #3
        It's required for living space because living people create moisture in the air. Aspiration, showers, cooking, etc.if you will be working wwith a lot of green lumber drying, or spraying a lot of water based finishes, maybe venting is a good idea, byut generally, a shop has doors and windows open quite often and is not heated as much as a living space so it doesn't drive the moisture up as much.
Mortar for Old Masonry
