I just added a 10″X18″ sheet metal duct that will provide fresh, outside air to 100K BTU gas furnace and 38K BTU gas water heater in my basement. The duct takes up almost all the space between two joists in the basement ceiling and is about 13 feet long. The basement is being finished and will be heated and cooled by a small heat pump. Should I try to inslulate this duct?
Fine Homebuilding Recommended Products
Respirator Mask
A full-face respirator prevents fog up and is more comfortable than constantly replacing particle makes that get fouled or sweaty and is ideal for the pro installer.
Milwaukee Cordless Shop Vac (0880-20)
This sleek, sturdy little vac is ultra compact but has plenty of power and the quietest operation.
Peel & Stick Underlayment
Often required by code, this durable, slip resistant, self-sealing, and self-adhered roofing underlayment is easy to install and ensures maximum protection along roof eaves, rakes, and valleys.
Flashing Boot Repair
Prolonged exposure to the sun and weather can compromise the rubber gasket on standard vent flashing. Use this to quickly and permanently fix failed seals or to help protect the gasket in new-construction applications.
Not So Big House
This book earned author Sarah Susanka a reputation as a small house guru, yet, that wasn’t exactly her goal. This book isn’t about building a small house, it’s about building a smart house, one that matches how we live, and prioritizing beauty and comfort over size.
James,
By all means, do insulate the ductwork to prevent condensation problems.
Is there not a better route for your ductwork that would be closer?
*Please elaborate on why you need to indroduce fresh outside air to your furnace and hw tank.Pete Draganic
I just added a 10"X18" sheet metal duct that will provide fresh, outside air to 100K BTU gas furnace and 38K BTU gas water heater in my basement. The duct takes up almost all the space between two joists in the basement ceiling and is about 13 feet long. The basement is being finished and will be heated and cooled by a small heat pump. Should I try to inslulate this duct?
