Insulating Garage Roof in Converstion Project
apollobelvedere | Posted in Energy, Heating & Insulation on July 21, 2011 11:09am
hi, I’ve got a project that I’m working on in my home to convert my garage into an interior space.
The roof of the garage is sloped and I’d like to keep the ceiling pitched so my plan is to put 4″ polyiso boards between the 2×6 frame, seal edges with spray foam insulation and then tack a 1/2″ sheet across the whole thing. Use furring strips over the 1/2″ sheet to hang the ceiling.
Oh and I live in Florida, is there anything that I should know or do differently?
All help and advice is much appreciated.
    xxPaulCPxx | Jul 23, 2011 05:18pm | #1
    That sounds like a great plan.  You could also - if desired - add a vent channel between the deck and the first layer of foam.  This would give you another thermal break and also provide another pathway out for a water penetration.
    1. apollobelvedere | Jul 24, 2011 08:49am | #2
      vent channel=adding ridge vent
      so does that also require installing a ridge vent?
        xxPaulCPxx | Jul 24, 2011 01:54pm | #3
        Yes it does, as it also requires soffit vents for every chute... it's just an option if you want to pursue it.
Versatile Vise
