Insulating house with no soffits
hogan | Posted in Energy, Heating & Insulation on January 30, 2004 07:43am
Hello everyone!
I need to add insulation to my attic floor. The roof and outside walls meet with no overhang. The ventilation that I do have is two gable vents and a powered roof fan. Looking to blow in insulation and was wondering if I could blow insulation all the way to where the roof and walls meet or do I have to leave some space. Do I still need to install the foam baffles on the roof in this area for air flow even though I do not have and soffit venting.
Hogan
    Sphere | Jan 30, 2004 07:47pm | #1
    in a word....nope.
    Go Stab yourself Ya Putz! Ya think I Parked here?
    1. hogan | Jan 30, 2004 07:50pm | #2
      No I can't insulate this way or no I don't have to install the baffles?
      Hogan
        Sphere | Jan 30, 2004 08:06pm | #3
        nope , ya don't need the baffles, they are to allow the soffit air a path to the ridge..in your situ. uneeded.
        1. xMikeSmith | Jan 30, 2004 10:08pm | #5
          like sphere said... the baffles only function is to provide a channel for air to move from the EXTERIOR thru a ventilated soffit up above the insulation and out thru , preferably, a ridge vent... or whatever vents you have..
           since you have NO SOFFIT VENTS.. you can insulate right to the eaves.. the more the merrier..
          now .. if there were some way for you to integrate an eave vent ( use your imagination )...then the baffles would be useful..
           bottom line.. no vents.. no baffles.. i like to keep my options open so we usually find a way of venting the eaves and adding ridge ventsMike Smith   Rhode Island : Design / Build / Repair / Restore
          1. xMikeSmith | Jan 30, 2004 10:10pm | #7
            what's the powered roof vent for?... i hope you don't use it during the winter..Mike Smith   Rhode Island : Design / Build / Repair / Restore
          2. hogan | Jan 30, 2004 11:01pm | #8
            Mike,
            The roof vent was installed this fall in a new roof. It's use will only be in the summer and is temp/humidity controlled. I intend to insulate this weekend. We currently are having some water back up in the house which is caused by a combination of some work currently being done on the house (new siding) but on a 8 degree day the snow and ice is still melting. Can you say heat loss? I looked up in the attic and pulled back what i thought was insulation that went to the eaves but there is a space of about 2 to 3 feet of open joists (no insulation). This is the reason for my questions. I didn't know if this was the correct practice or not.
            Thank you all for you suggestions and wish me well in my insulation fun
            Hogan
          3. AndyEngel | Jan 31, 2004 12:21am | #9
            Have you foamed any penetrations that might connect the conditioned space of the house with the attic? That's every bit as critical a step as insulating, especially if you intend to use fiberglass batts.Andy Engel, The Former Accidental Moderator
          4. hogan | Jan 31, 2004 02:57am | #10
            Andy,
            That is in my plans. Thanks
            Hogan
            NickNukeEm | Feb 07, 2004 05:36pm | #11
            Make sure there's no knob and tube wiring in the voids before insulating, if the house is that old.  (See current thread on removing K&T.)  If not, disregard and happy insulating.
  2. MojoMan | Jan 30, 2004 10:03pm | #4
    Well, maybe. How old is your roof? If you use baffles, the next time you re-roof, you could install vented drip edge.
    Al Mollitor, Sharon MA
    1. AndyEngel | Jan 30, 2004 10:08pm | #6
      Why vent a perfectly good roof? Here's a perfect house to experiment with. There's no venting now, to speak of. Blow that sucker full of cellulose and see what happens.Andy Engel, The Former Accidental Moderator
