Insulating interior bathroom walls
pgproject | Posted in General Discussion on November 21, 2005 06:06am
What’s the current wisdom on insulating the interior bathroom walls? I’m looking for sound isolation from adjoining rooms, but am worried about moisture retention, as this is a very humid climate.
Thanks!!
  1. PatchogPhil | Nov 21, 2005 07:18pm | #1
    Moisture retention on interior residential walls?  Sounds like a leak somewhere rather than moisture from the bathroom air.
    For sound isolation I used rockwool (Roxul brand) on interior walls.  Works very well.  I also stuffed it under and around the acrylic shower/tub.
    Hopefully you have a very good and proper sized exhaust fan for the bathroom that exits outside.  Panasonic fans are efficient, quiet and long lasting.
    Proper tub/shower enclosure construction for moisture sealing along with good quality bathroom paint will keep the moisture out of the walls.
    1. pgproject | Nov 21, 2005 08:38pm | #2
      Thanks for the reply- I've done all the things you mentioned. just worried that if there is a failure of all the waterproffing (especially around the shower/tub enclosure) that the insulation will trap any moisture that gets in the wall cavity.Bill
      1. PatchogPhil | Nov 21, 2005 09:08pm | #3
        If water gets in there,  it is a problem regardless of if there is insulation or no insulation.
        1. pgproject | Nov 22, 2005 08:46am | #4
          agreed- I'll insulatethanks
A Practical Perfect Wall
  • The New Old Colonial
