How do you insulate a basement wall that has been framed with metalstuds, using fiberglass insulation?
In this FHB Podcast segment, the crew offers expert advice on insulating an old home and finding the right contractor to do the job.
How do you insulate a wall that has been framed with metal studs using fiberglass insulation?
Your drywall supplier may be able to supply you with fb that is sixteen inches wide and will friction fit between the metal studs. If this is unsuccessfull try other commercial building supply houses in your area. Oh are you going to gyp. both sides of the walls?
*Your drywall supplier may be able to supply you with fb that is sixteen inches wide and will friction fit between the metal studs. If this is unsuccessfull try other commercial building supply houses in your area. Oh are you going to gyp. both sides of the walls?
