insulation
davejitsu | Posted in Energy, Heating & Insulation on January 12, 2009 04:05am
What would be the best way to insulate under a house that is on stilts. Home is on beach south shore long island. Thank you
  1. Clewless1 | Jan 12, 2009 04:39pm | #1
    Fiberglass batts should work OK I would think ... properly installed. Then install a 'pan' of e.g. plywood (or more durable finish) underneath secured by say stainless fasteners to enable easy access for maintenance and repairs ... making special provisions for 'special' areas (e.g. around kitchen or bath plumbing).
    I don't have much experience w/ the harsh sea side environment ... maybe someone else can chime in w/ some additional thoughts.
  2. MikeHennessy | Jan 12, 2009 04:45pm | #2
    The "best" way would probably be foam since it's more resistant to the spray/high humidity in a shore environment.
    Mike Hennessy
    Pittsburgh, PA
