I have 2×6 rafters in my split- level with no ridge vents. I want to open up cathedral ceilings in the main floor. Whats the best way to insulate and keep proper air flow in the rafters?
The code requires installing an approved material to stop the spread of fire between floors and adjacent vertical and horizontal cavities — here are the allowed materials and required locations.
2X6 is pretty tight for air flow. I guess you could put some 1" baffles up against the plywood and then spray urethane(4") up against that, maybe a ridgevent. That would give you a R-28, maybe.
Just having 5 1/2" to insulate doesn't give you alot of options. If you use fiberglass it's going to condensate. You could spray foam 5" which should give you a R-35 but no airspace.
I don't know if this helps you or not. It's just my two cents worth.
Dave
Thanks Dave, The other option I've considered is to frame out the rafters to a full 12'' with a channel from eave to a ridge vent. That way I get more R-value and good air flow but the cost I'm looking into. The spray foam sounds good but I'm skeptical about it with some things I've heard. Thanks for the 2 cents.
If you haven't already, consider the structural loads, and where they are going to go, from removing the ceiling/ceiling joists, and how that will affect wall spread. You didn't mention how the house is framed, but it's a point that needs to be considered.
As you mentioned, you may need to add on to the 2-6s for increased depth. You might be able to get enough just by adding 2x4s cross-wise.
Anyhow's, you might be able to use a derivation of this: http://forums.taunton.com/tp-breaktime/messages?msg=39539.2
