Insulation for a old brick house
user-533054 | Posted in Energy, Heating & Insulation on October 14, 2002 06:04am
I have a 100+ year old brick house in Wisconsin, and I mean
layer of brick on the outside and a layer on the inside with the plaster right over the inside layer of brick. There is a 3-4″ air space between the brick layers (12″ wall thickness). could this be filled with some sort of insulation? the outer brick is red and seems to absorb water easily. I am conserned that if i fill the void, the brick would not breath and start to crack or crumble. As i mentioned,
the house was built about 1893ish, and does not have any
cracks or morter issues currently. I have insulated rooms as i
have renovated by studding and installing batts or hardboard
insulation, but several rooms are not suited to have this done. I
would like to have walls that are not so cold in the winter, any
suggestions??
