Insulation for this addition
chrisr710 | Posted in Energy, Heating & Insulation on August 3, 2018 01:30am
Hello:
I am working on this addition to my home, shown in the picture. I was wondering if anyone has some advice/insights into insulating the new rooms (it’s ~ 11′ x 40′).
My plan was to used closed cell insulation in the 2×10 rafter bays, from my understanding I can do that and don’t need to leave an airgap and use a vapor barrier (the closed cell will keep moist air from going up to the roof and condensing). I was going to use regular fiberglass batts on the floor and in the walls.
If I do that
1) what should I do about the closed-off soffit area? (area B on the pic) It is separated from the inside by blocking on all rafters. Can I just fill that up with foam too and then close off the bottom? Do I need to vent it somehow? I was going to use T&G pine boards as my soffit, and wrap the housewrap up under them before putting them on.
2) what should I do about the cantilevered area under the wall? (are A on the pic) It is also closed off from the inside because of blocking. I was going to cover the bottom of that up the same as with the soffit, painted T&G pine and run the housewrap under there too. Can I fill that up with either foam or fiberglass batts, and if so do I need to vent it?
3) Finally, the other option would be the more traditional way of using fiberglass batts on the ceiling too. Then I could use soffit vents and put an air gap above the insulation, and it would have the added benefits of ventilating the house roof (since I can’t put soffit vents on the house roof now that the addition is there, the air gap could extend all the way up to the attic).
I appreciate any advice.
Thanks! This forum has helped me build this thing so far from the ground up.
As requested, here is climage info:
  • climate zone 5 according to IECC (Northern Colorado, Weld County).
  • Minimum R38 on the roof, according our building department.
  • Weld County, Colorado gets 14 inches of rain, on average, per year
  • Weld County averages 34 inches of snow per year.
  • Summer High: the July high is around 90 degrees
  • Winter Low: the January low is 15
  • elevation ~ 5000 ft
  • roof is modified bit roll roofing, older house roof is asphalt shingles.
  • There are gable vents on each side of the existing roof.
  1. DanH | Aug 03, 2018 07:35am | #1
    Climate??
    1. chrisr710 | Aug 03, 2018 11:43am | #2
      Climate
      Sorry, that would be climate zone 5 according to IECC (Northern Colorado, Weld County). It's windy, fairly dry, cold in winter and hot in summer. Minimum R38 on the roof, according our building department.
      elevation ~ 5000 ft
      Is that enough info?
      Chris
