Insulation in Northern Saskatchewan, my planned wall
jab99 | Posted in Energy, Heating & Insulation on October 16, 2012 11:15am
Hello
Here is wall detail
Certainteed Membrane vapour barrier (breathable if wall humidity get too high)
Roxul batt insulation (2×6 wall)
Plywood sheathing ( handles any accidental moisture better)
Typar Drain wrap (allows small air sapce behind foam)
2 layers of stagered 1.5 inch eps exterior foam board (breathable to exterior)
1 x 4  firring strips (rain screen)
Hardie board siding. (my wife loves it)
Widows are in installed as innie’s with Azek exterior jamb extensions. (tripple pane dual low e and argon)
Goal, be economical, reduce all thermal gaps and be airtight.
Thoughts???
    xxPaulCPxx | Oct 17, 2012 12:25pm | #1
    Why Roxul and not Cellulose?
    Why inset?  I could see snow piling up on the windowsills... and where will the cat perch?
