Insulation on 1/4 inch drywall
michaeldrehl | Posted in Construction Techniques on September 5, 2018 04:48am
Hi, I have a house that had plaster and lath ceiling. There was another ceiling created with 1/4 inch drywall and 2×4 screwed in the wall. There is a feet of space between the plaster ceiling and drywall. I wanted to place or slide fiberglass insulation in the ceiling from the top in attic space. From the attic, I see that the plaster has large gaps and wholes. I would cut a linear opening in the plaster and slide the insulation. My worry is that since it is a 1/4 inch drywall, the fiberglass insulation will cause it to sag.
I’m thinking of using R-13 batts. To lower the weight, I was thinking of ripping half of fiberglass off. Even with lower and half of the  R-Value, at least there would be some insulation than nothing.
Any thoughts?
Thank you for your help.
  1. mgmahan | Sep 05, 2018 05:03pm | #1
    Best advice.
    Get rid of the drywall ceiling. Repair the plaster. Insulate above.
    Second best advice. Insulate above the plaster.
    1/4 drywall will sag under its own weight if it hasn't already.
    Mike
    sawdust_steve | Sep 06, 2018 11:58am | #2
    It's very unusal to use 1/4 inch drywall. Mostly it's used when laminating over en existing surface or as  two layers when you need a curved surface. Are you sure its 14 inch and not 1/2 ?
    If you trust the framing you could go over the 1/4 inch with 1/2 inch drywall. I would not suggest trying to snake in batts of finsualtion through the hoels you willnot get 100% coverage. Rather try blown in cellulose or spray foam.
    1. michaeldrehl | Nov 03, 2018 02:04pm | #4
      My mistake. It's actually 3/8 inch drywall ceiling.
      Can I still cut and insulate above the Sheetrock? Or it needs to be 1/2 inch?
    sawdust_steve | Sep 06, 2018 11:58am | #3
  4. florida | Nov 05, 2018 02:15pm | #5
    It will never work. In spite of what everyone thinks fiberglass is very hard to install so that it actually works. It's very fussy work that demands a perfect fit everwhere or you will be throwing your money away. There is no way you can cram it in a small space, poke it around with stick and do a good job. Small voids will cancel out any insulation factor you could achieve.
    1. michaeldrehl | Nov 05, 2018 04:06pm | #6
      Thank you for your input. But will the insulation cause the 3/8 inch drywall to sag? or the drywall needs to be 1/2 inch?
      1. oldhand | Nov 05, 2018 06:42pm | #7
        3/8'?
        How far apart are the supports? Sometimes even 1/2" will sag with 24" 0.c.
        1. michaeldrehl | Nov 05, 2018 06:50pm | #8
          The wooden 2x4s are about 14 inches apart.
      2. florida | Nov 05, 2018 08:27pm | #9
        If you push insulation into the space the 3/8' drywall will develop lumps and bumps.
Outdoor Lighting
