Insulation Swim Meet
etherhuffer | Posted in General Discussion on September 20, 2007 07:56am
I have to go swimming in the attic to add some wires not done correctly to an alarm. They were pulled individually to the panel and should have been daisy chained. Lay down a piece of plywood over the blown in and fluff it up as I retreat?
www.etherhuffer.typepad.com
  1. jet | Sep 20, 2007 08:00pm | #1
    Real men dive in and scratch later. Then snuggle up to DW!!! LOL
    "No doubt exists that all women are crazy; it's only a question of degree." - W.C. Fields
    IMERC | Sep 20, 2007 08:03pm | #2
    jet has the word...
    WOW!!! What a Ride!
    1. etherhuffer | Sep 20, 2007 08:14pm | #3
      Gee thanks. I guess. !!!!http://www.etherhuffer.typepad.com
        IMERC | Sep 20, 2007 08:18pm | #4
        let us know what the DW has to say about this if you would please...
        IMERC | Sep 20, 2007 08:19pm | #5
        actually you are better off being very careful moving around...
        the ply will compress the insulation and derate it...
        1. etherhuffer | Sep 20, 2007 08:45pm | #6
          If I don't step through the ceiling, that will be enough to keep us happy!http://www.etherhuffer.typepad.com
            IMERC | Sep 20, 2007 08:50pm | #7
            becareful...
            use the brail system every step of the way...
            put the insulation back the way ya found it as you withdraw...
  3. woodturner9 | Sep 20, 2007 08:52pm | #8
    Can't you just tie them together at the panel?
    1. etherhuffer | Sep 20, 2007 08:57pm | #9
      Well, we thought so. But the panel does not see it that way and every alarm person I know says they have to daisy chain so that the panel can supervise them properly.http://www.etherhuffer.typepad.com
        IMERC | Sep 20, 2007 09:03pm | #10
        you talking about series or parralell wiring???
        1. etherhuffer | Sep 20, 2007 09:13pm | #11
          Parallel is how the diagram shows. Its a two wire system, each wire running to the same leads on each detector, ending with a 300 ohm resistor. http://www.etherhuffer.typepad.com
            IMERC | Sep 20, 2007 09:29pm | #12
            how is the pannel wired...
            IMERC | Sep 20, 2007 09:30pm | #13
            got a pic???
            IMERC | Sep 20, 2007 09:31pm | #14
            who made the panel???
          4. etherhuffer | Sep 20, 2007 09:57pm | #15
            There are 2 wires at the panel that go out. Its an Ademco Vista 20 split panel. Each of the two wires hits the same lead screw on the detector and then on to the next. An end of line resistor is at the last detector. Sorry, no pics so far. http://www.etherhuffer.typepad.com
            IMERC | Sep 20, 2007 10:10pm | #16
            That's a moose panel IIIRC...
            is the EOL resistor polarity sensitive???
          6. etherhuffer | Sep 20, 2007 10:36pm | #17
            Not sure on that. Are the resistor ends marked as such?http://www.etherhuffer.typepad.com
          7. User avater
            IMERC | Sep 21, 2007 12:24am | #22
            not the resistor for polarity...
            wiring the sensores to the panel... polarity for them...
            the expansion board is a great idea...
            can ya post the schematic or email it...
            somethin g tells me this a series wire up and you should be able to do that right at the panel with a load strip or just twist up the appropiate leads and wire cap...
            where are you???
          8. etherhuffer | Sep 21, 2007 12:58am | #23
            Seattle. I will have to dig stuff up and repost when I find it. Is an expansion panel just another circuit board I add in?http://www.etherhuffer.typepad.com
          9. User avater
            IMERC | Sep 21, 2007 12:59am | #24
            yup....
            cake and pie...
            the paper work tells all...
          10. User avater
            IMERC | Sep 21, 2007 01:03am | #25
            lets look into the series aspect... you may be able to go that way...
            as said the expansion panel gives ya multiple zones and easy to trouble shoot in the future as where a series loop can develope gremlins...
            is yur system working now and how old is it???
          11. etherhuffer | Sep 21, 2007 01:24am | #27
            We have a 10 year old partitioned system. One side controls the mother in law apartment alarm and fire. The other side the upstairs alarm. We are now finishing the upstairs so we are adding fire to the upstairs area. The two smoke heads in the MIL work ok. We added 3 smokes and one heat riser upstairs, pulling wire to the panel from each. Tried to connect them at the box but no go. Could not get the sensors to trip the alarm. At that point we stopped. So the two MIL smoke heads are tied together, the others are single run. That is where I think our problem is.
            The Vista 4219 expansion panel allows 8 end of line monitored devices to be added. I could add my four new detectors and leave the old fire circuit alone? That would be easy and relatively cheap. 80 bucks for the panel. http://www.etherhuffer.typepad.com
          12. User avater
            IMERC | Sep 21, 2007 02:58am | #28
            go for the panel....
          13. User avater
            Gunner | Sep 21, 2007 05:22am | #31
               OK I asked my question before I read all the way through. The other guys are right Its better to have each one on their own point. Vista is a good panel. I'm going to install one in my sisters new house for a house warming present when the get it done.
            "I tell you, We are here on earth to fart around, and don't let anybody tell you any different."  Kurt Vonnegut jr.
            http://www.youtube.com/watch?v=e5MG1ZfFiZ8
            Edited 9/20/2007 10:23 pm ET by Gunner
          14. etherhuffer | Oct 02, 2007 07:35am | #32
            Well, I checked on some alarm forums. Sounds like I can't do an expansion panel as smokes won't work one to a zone due to power supply problems. Back to the insulation swimming.http://www.etherhuffer.typepad.com
          15. User avater
            BillHartmann | Oct 02, 2007 08:06am | #33
            I still don't understand the problem.If I understand correctly you have a separate pair back from each alarm to the location of the alarm panel.At the point you can hook them all up in parallel or in series however you like.Don't know what you will gain by running new wires..
  4. DanH | Sep 20, 2007 10:46pm | #18
    Make the plywood into a "sled" with 2xwhateverworks attached along the two long edges. Also get some pieces of about 1" dowel rod (or something similar) to lay between joists when your sled "runners" will be parallel to the joists.
    1. etherhuffer | Sep 20, 2007 11:01pm | #19
      If I bevel the fronts of the 2x4s I can ride down the roof when I am done!http://www.etherhuffer.typepad.com
      1. MikeSmith | Sep 21, 2007 05:19am | #30
        ether.. i might bring a piece of ply with me.. but the way i'd get there would be like imerc said
        brail method
        one foot on a ceiling joist / truss chord / framing member.. centered.. then next foot on next.. & so on..
        don't do a weight transfer until you're sure of your next footingMike Smith Rhode Island : Design / Build / Repair / Restore
  5. jganyard | Sep 20, 2007 11:51pm | #20
    Whoever did your LV wiring did a good job.  Now you can monitor each sensor on it's own individual zone.  Just get an explansion panel for your board if you don't already have enough.
    1. etherhuffer | Sep 21, 2007 12:19am | #21
      You lost me on that one. ???????http://www.etherhuffer.typepad.com
  6. MSA1 | Sep 21, 2007 01:23am | #26
    Dont forget your mask.
  7. User avater
    Gunner | Sep 21, 2007 05:14am | #29
       You can't fix that at the panel? Series them together right there?
Grout-Free Shower Panels
