Insulative value of lath and plaster?
SaturdayNight | Posted in General Discussion on September 22, 2007 01:25am
A prospective client today was expounding to me about the insulative value of lath and plaster.  I didn’t contradict him, but that was a new one to me.  In older home remodels, I am always advocating replacing old lath and plaster for drywall.  Am I missing something, Piffin?
  1. Piffin | Sep 22, 2007 02:47am | #1
    I think it is your client who is missing something - whatever used to be where that hole in his head is.
    Both have R-values around .5/inch.
    Since the normal thickness averages 5/8" or less, that means an R-value of about .25.
    Even if one is better insulation than the other the percentage of .25 in a typical wall is worth about as much as a sheet of cardboard.
    'course there are people who will swear that cardboard is fine insulation...
    1. DanH | Sep 22, 2007 03:49am | #4
      Depending on the method of application, plaster can have a thickness in excess of an inch. Add rock lathe to that and you could be up to an inch and a half without much difficulty.
  2. Billy | Sep 22, 2007 03:40am | #2
    Maybe he was thinking about the thermal mass of plaster, which can be pretty good, but as you know that's a totally different animal from insulation.
    Billy
  3. DanH | Sep 22, 2007 03:47am | #3
    Yeah, plaster is a lousy insulator but has a lot of thermal mass. It also, if sound, is very "tight" and inhibits air infiltration pretty well (though air can still infiltrate through outlets, around door/window frames, etc). Thermal mass and low infiltration can make an uninsulated house a lot more comfortable in the right circumstaances, though certainly good insulation will make it more comfortable.
