What is the minimum standard as far as interior house painting of enamal woodwork on tract homes. I assume that an association sets the guidelines. What I am looking for is something like this; prime wood, sand smooth, spray paint coat, sand and spray final paint coat. GW
Listeners write in about deepening foundations and ask questions about HRVs, smoothing rough concrete, and finding the right workwear.
SawStop's Portable Tablesaw is Bigger and Better Than BeforeRelated Stories
Podcast Episode 665: Rough Concrete, Good Workwear, and Framing a High-Performance House
Podcast Episode 664: The Best of the Fine Homebuilding Podcast, Volume 8
FHB Podcast Segment: The Best of the Fine Homebuilding Podcast, Volume 8
Podcast Episode 663: Green Stains, Larsen Trusses, and Insulating Behind Stucco
Greg, You seem to have been sitting here for quite awhile. Perhaps your trim is already painted. I never have heard of any minimum standards for paint grade. Not to say that there isn't, but my experience (and I am not a tract home builder) is the standards are found in the plan specs and it is up to the individual painter/builder to set acceptence levels for work.
It seems now a days, even on custom high end work, the trim is painted or stained with one coat of finish on before it is even installed. Final sanding/finish coat be it paint or finish is then applied after nails are puttyed (if they be filled). The sanding between coats is a touch of professionalism that good painters use, but do not expect it especially in a tract home.
many blessings on your new home
walk good
david
*minimum standard or "fine homebuilding"inspect previous trades workputty holes (nails should already be set, but maybe everyone else is working by minimum standards as well)remove doors and hardwareremove window hardwareremove cabinet doors and hardware maskcover finished flooring (if present) with heavy construction paper or adhesive backed plasticsand woodwork wipe clean (rag and thinner)primesand (light)... hopefully woodwork was preprimed, jambs back-primedcaulk joints1st coatsand (light)2nd coatreinstall all hardware, doors, cabinet doorsclean upbrian
*There's actually a spec book written about this. The idea is that a contract would call out the spec. There are three levels, depending on the quality of the job. I can't remember the title, but I think the discussion of it was in the Journal of Light Construction several years ago. I'm sorry I can't be more help.
