Is a subfloor on top of 1″ of XPS foam unecessary?
apiersma | Posted in Construction Techniques on January 17, 2012 06:22am
I’m remodeling a basement that is dry. I propose to glue down 1″ of XPS foam, then install a wood laminate floating floor on top. Adding in a plywood subfloor seesm extraneous if you are going to float a floor above it. Has anyone done this?
  1. DanH | Jan 17, 2012 11:36pm | #1
    Laminate flooring is not rigid -- it will flex at the joints.  When you walk on it or put heavy furniture on it the developed PSI can likely exceed the strength of the foam.
  2. [email protected] | Jan 20, 2012 02:43pm | #2
    The foam will break down over time.
    You need a subfloor that is stiff enough it won't transfer point loads to the foam.
    Try asking the tech support folks at Dow for their recommendations.
