Is Tar Applied To Outer Surface Of Plywood Walls
jimmiem | Posted in Construction Techniques on February 23, 2017 08:31am
There is a commercial construction project underway near my home.  It’s a combination retail store/multi story apartment complex.  I drive by there daily.  The apartment portion is wood frame with plywood sheathing on the walls.  I noticed that a black substance is being applied to the plywood wall sheathing.  Would this be tar?  I don’t ever recall seeing anything like this.
  1. DanH | Feb 23, 2017 09:10am | #1
    There are all sorts of schemes for treating sheathing.  What you see is likely not literally "tar", but some sort of "polymer coating".
    sawdust_steve | Feb 23, 2017 09:30am | #2
    No one uses tar. Fluid applied water proofing maybe? Sheet memebrane like ice & water shield (looks black once in place).
    What's your concern?
    1. jimmiem | Feb 23, 2017 03:20pm | #3
      Just curious.  I'd never seen anything like that before on side walls.....used to seeing Tvyek type housewrap.
      1. florida | Feb 24, 2017 09:06am | #4
        I've never seen a liquid water barrier applied but constructiuon technology moves on. I was told years ago by a large, national window company rep that they were switching their window installation procedures from flashing tape to liquid membranes.  Makes a lot of sense if you think about it. Flashing tapes are pressure sensitive but I've never seen anyone besides my guys using a roller on them so a liquid is proably more dummy proof.
    user-2409187 | Feb 24, 2017 10:06am | #5
    Wait a bit longer and you may see an EIFS product installed on the walls. Critical to the performance of the system is a drainage bed or some other way for protecting exterior wall sheathing from moisture damage. Where an EIFS (exterior insulated foam system) is used you don't typically install house wrap. Liquid membranes are relatively new. I use them from time to time.
