Is there a better way to mount hose bib, electric outlet prior to Hardie siding?
I am building a new house and getting ready for the siding. The hose bibs, electric boxes and dryer vent have all be located and plumbed or wired but
I haven’t mounted the boxes on the 1/2″ osb wall sheathing.
Contractors are all mounting the hose bibs dryer vents on a block and then
installing Hardie plank around them.
Is there a better way to mount these utilities? I’ve seen the blocks crack after
a few years. What about using 1x material instead of 2x material?
Rick
PVC block?
Anything, if the mounting screw holes are sized for the screw thread to pass through, and pre drilled for mounting to the osb.
