Is there a way to fix 1/4 gaps in a hardwood floor?
ColinFitz | Posted in Construction Techniques on March 16, 2013 07:29am
We have a client in Marstons Mills on Cape Cod with a random width wood floor and the filler is crumbling and coming out. The floor is only two years old, but was obviously installed improperly. Is there any good way to repair it?
  1. DanH | Mar 16, 2013 08:21pm | #1
    The fact that there was filler in the original work suggests that it was a crummy job from the start, done with materials that were way too wet.  (Though probably this is an on-going problem on Cape Cod -- you're practically sitting in a swamp.)
    It looks like "engineered" flooring of some sort.  It might be possible to pull it up and re-lay it.
  2. junkhound | Mar 17, 2013 11:02pm | #2
    Durham's rock hard
    But, ya gotta get all the soft crap out of there first.  Like Dan says, pretty crummy job with those big gaps.  Any possibility of pressure washing ? (probably not an option if finished ceiling underneath)
    1. sapwood | Mar 18, 2013 11:11am | #5
      Really?
      Do you really advocate pressure washing a hardwood (engineered or otherwise) floor? Just how would that process help?
  3. junkhound | Mar 17, 2013 11:04pm | #3
    Durham's rock hard But, ya
    edit delete, duplicate, response so slow thought the post key had not been hit....
  4. florida | Mar 18, 2013 09:28am | #4
    No, there is no good way to fix it. There are several bad ways but obviously one of the bad ways has already been tried. No filler made is going to both look good and keep the cracks filled. Wood floors move too much for a hard filler to stay put and a filler that stayed pliable would look terrible. I expect you already know the answer.
      ColinFitz | Mar 18, 2013 02:40pm | #6
      Re-installing wood floor
      Do you think it is feasible to reuse the existing wood flooring?
      1. [email protected] | Mar 18, 2013 05:58pm | #7
        Reuse?
        Possible to reuse the exisitng, sure at least some of it could be.  But it will take a lot of labor to pull it up with out damage, and even more to remill tongues and grooves if needed.
        By the time you cost in that labor it will be far less expensive to rip it out and install new flooring.  Particularly if the existing is engineered hardwood.
        It looks like an attempt to float an engineered floor that had glue failure at the joints, and then someone tried to patch up.
      2. DanH | Mar 18, 2013 07:18pm | #8
        How is the flooring fastened?
          ColinFitz | Mar 18, 2013 10:15pm | #9
          Flooring Fastened
          The flooring is 3/4" T&G solid hardwood and I think it must be fastened with nails because it squeaks now when walked on.
          1. DanH | Mar 18, 2013 10:32pm | #11
            That little bit you can see through the crack look more like some sort of laminated flooring.
      3. florida | Mar 19, 2013 07:26am | #12
        Since you're taking it up anyway the additional time to remove it carefully could be worthwhile. You may not be able to save but half cost effectively  but I'd give it a try anyway.
    ColinFitz | Mar 18, 2013 10:17pm | #10
    Fixed Floor
    Sounds like a good solution, unfortunately this floor is throughout the whole house.
  6. ChuckKiser | Mar 20, 2013 08:12am | #13
    Based on the photo it appears to be a engineered laminate, snap / click type flooring. These are meant to be floating installations over a vapor barrier. It should never be nailed or glued. Leave a 1/4" gap at the walls and cover with base shoe. do not nail the shoe to the floor. Nail the shoe to the baseboard.
    1. finefinish | Mar 23, 2013 09:57am | #14
      Hey Chuck, Colin responded to another poster that it looked like laminate, but it is actually 3/4" solid.  It's just the tongue that we are seeing where the boards are gapped.  Good advice though about working with laminates.
  7. toolpouchguy | Mar 24, 2013 07:17am | #15
    there is
    Tear it up
