Is this insulation ok in this way?
Hello guys, Here I attached a few pictures of how the store delivered the insulation materials. Is it ok to have foam panels damaged like this and the fiberglass batts squeezed in that way? I have been told to not squeeze it. Maybe I’m asking something stupid, but just for a learning purpose. Thank you.
I personally wouldn’t worry about the fiberglass. As for the foam, it depends, does every piece look like that, or just the top piece that was strapped without a corner support? If only a couple of pieces, I would assume you’d be trimming a couple or few pieces to fit anyway. And if you’ll be using any spray foam for gaps that’ll take care of a couple of dents.
Thank you. Only few pieces were like that, and I managed to cut around.
Material “mis”handling! The foam would be in the seconds pile at a box store. Ask for a price break. Same goes with the banded Fiberglas.
What’d they have a hundred mile drive on the interstate?
Thank you Calvin.
