Is this ok? Water intrusion between footing and foundation
NWCarpenter | Posted in General Discussion on February 28, 2018 10:51am
This is by a private home inspector. The crawl has a drain to daylight from the lowest point and gravel on top of the grade.
Do you see any reason for concern?
Thank you!
  1. calvin | Mar 01, 2018 07:08am | #1
    Thank you!
    Yes, to the question of concern.
  2. DanH | Mar 01, 2018 07:57am | #2
    It means that the house needs downspout extensions.
    1. NWCarpenter | Mar 01, 2018 09:54pm | #3
      Maybe but
      the house was designed and approved for downspouts to splashblocks and is built that way.
      1. DanH | Mar 02, 2018 08:25am | #4
        Did I say it wasn't?
        You have fairly minor water intrusion.  You need to make sure that rainwater doesn't stand near the foundation.  Mostly this is a matter of properly grading around the house, and using other measures (the extensions) to assure that water doesn't stand nearby.
        What usually happens with a new structure is that the foundation is built and the soil is backfilled around it.  Things look good.  But a few years later the backfill has settled down, and low spots develop.
        One way or another -- adding soil, mud-jacking slabs, adding downspout extensions or underground drains for the downspouts -- you need to assure that water never "stands" within about 10 feet of the foundation.
Mortar for Old Masonry
