Looking for a paint to use on concrete (concrete block) basement walls. Area will be a woodshop. Desire gloss, which will be easy to clean.
Thanks,
Gordy
Gordy:
The following is the cadillac of block coatings:
Tnemec 54-562 modified epoxy masonry filler followed by topcoats of Tnemec series of your choice gloss or flat. Check w/ your cmu supplier.
I've used Rustoleum Epoxy floor products. Awesome wear characteristics. I use the 100% solids, two coats.
Sherwin Williams has a line of epoxy products, both water and solvent based, rated for concrete. I've not used these but the specs look good. Ask for their "industrial Coatings Guide". You won't find these products out in the front of the store.
*GordyCheck out Keim Mineral Paints. They're not a coating and are intended for outdoor use but may be suitable. http://www.spec-net.com.au/keim/index.htm
I have used Dry-Lock. It will take at least two coats using a large roller with a long nap. In using the roller you have to push the paint sideways to get it to fill in the holes. After it has dried you can use any good grade of latex semi gloss in what ever color seems best.
Thanks,
Gordy
Start with a concrete block filler. This is a portland based "paint" you mix from powder. Roll it on and work it in with a bristle brush and clean off the excess (unless you want a stucco appearance). Will fill the small voids in the block and give you better coverage when you apply your choice of real paint. Smoother finish too.
Cheep stuff. You should be able to get it where you buy your blocks. Have also seen it at Lowe's. Understand some folks do the same thing with drywall mud (fill the voids). Not something I would recommend for below grade or any other situation where moisture could be a problem.
