Its not my piece….
txkevin | Posted in General Discussion on July 11, 2007 05:58am
I have a wall that will be stone masonry that passes through a roof line and is supported beneith by a 4×6 lintel (per engineer specs).   I am sure through wall flashing needs to be installed where the stone passed throught the roof line.  Who installs this, the Masonry sub or the Roofing Sub?  Neither claim the piece.
If this falls to me, can anyone recommend a best material and technique to accomplish this to assure that the water that gets behind the stone wall will not migrate to the bedroom beneith.
Thanks in advance.
    bambam | Jul 11, 2007 06:13pm | #1
    If I'm reading you right it should be both.
    The masonry sub will install flashing as they lay the stone.
    The roofer will install step flashing to the brick layers flashing.
    1. txkevin | Jul 11, 2007 06:24pm | #2
      But the through wall flashing will be the Mason's responsibility correct?
        bambam | Jul 11, 2007 06:38pm | #4
        Yeah, what Dan said.
        The mason will install his flashing above the roof line. It will be imbedded in the stone and turn down. If you have to cut it in later it will look like it was added later. (which it would be) The mason can can use the right stones while installing to make it look better.
        Then the roofer will install his step flashing from the roof to make it water tight.
        1. DanH | Jul 11, 2007 06:42pm | #6
          Like I said, you do it like a chimney (the side of one at least):
            bambam | Jul 11, 2007 06:51pm | #7
            Thats a good pic of what he needs. I try to find stuff like that but I dont have much luck.
            I'm thinking on a stone wall, if the mason doesnt install it then it will never look right.
          2. DanH | Jul 11, 2007 06:54pm | #8
            Yeah, the pieces behind the flashing need to have relatively flat faces, or the flashing won't fit well. And it's a beech to have to grind away the stone because the mason didn't set in flat ones.
            BillHartmann | Jul 11, 2007 07:07pm | #11
            Here is TROUGH flashing.http://forums.taunton.com/n/mb/message.asp?webtag=tp-breaktime&msg=73904.1&maxT=8Here is a general thread about who does what on flashing a chimney.http://forums.taunton.com/n/mb/message.asp?webtag=tp-breaktime&msg=79798.1&maxT=14
          4. theslateman | Jul 11, 2007 11:58pm | #15
            Thanks for the  thread  locating job.
            I doubt if I could have found it!
            Walter
            BillHartmann | Jul 11, 2007 06:58pm | #9
            That is not THROUGH flashing.From what I have heard stone should be THROUGH flashed.I could not find a picture of it. But I think Mike Smith might have one posted one in progress.This is a close as I could find.http://www.crsmca.org/publications/featured-article
          6. DanH | Jul 11, 2007 07:04pm | #10
            Seems like through flashing would only be needed (if then) if the wall is stone veneer. Wouldn't make sense for solid stone (through to what?).
          7. txkevin | Jul 11, 2007 07:23pm | #12
            i am pretty sure that through the wall flashing is necessary to assure that any moisture that gets behind the wall does not end up in the bedroom.  Masonry is not waterproof thus the need for weep holes.   Of course I do not claim to be even close to a mason and may not know my rear from a rock in this regard.
            It seems both have a role to play in this.  It seems reasonable that he roofer's part is after the masonry though and no flashing that he is responsible for should be installed prior to masonry.  It seems the mason should install the through wall flashing during his installation and the roofing contractor should tie into his work.  I need to talk to my mason it seems.....
  2. DanH | Jul 11, 2007 06:28pm | #3
    Should be done like a chimney. Best if the mason installs the top pieces of flashing (forget the specific term) and then the roofer does the step flashing. If the mason doesn't do it, someone has to use a masonry saw to cut slots in the wall to install the flashing.
    Edited 7/11/2007 11:29 am by DanH
    bambam | Jul 11, 2007 06:41pm | #5
    I just reread your post.
    You say neither claim the flashing?
    You may need to find some new subs.
    jonblakemore | Jul 11, 2007 07:54pm | #13
    As others have said, you need the mason & roofer to work together on this area where you need through flashing. Since you're applying stone veneer, you need your counter flashing to extend from the exterior side of the stone all the way back to the side wall. If you do not through flash and the cap leaks or any water penetrates behind the veneer you will have a leak that will travel down the wall until it hits something and causes a leak problem.
    One this counterflashing is installed, the roofer can install the step flashing under the counterflashing and it should be water tight.
    Jon Blakemore
    1. txkevin | Jul 11, 2007 09:59pm | #14
      Thanks to all for the info.  I have an idea of what needs to be done at this point and at least know what I am looking for.
