Jacuzzi Electric Wiring Problem
hvac2000 | Posted in General Discussion on October 24, 2006 02:30am
Hi! I have a customer that has a jacuzzi on the second floor. There is a 20 minute timer in series with the pump. I have no power at all going into the timer box. I checked all the GFI’s in the area and they all work. There is power at the circuit breaker box. Is there any trick to find were the fault took place? Here Illinois we are suppose to have a dedicated circuit going to the jaccuzi. Not sure if that would help you figure this out. Thanks Jay
  1. DanH | Oct 24, 2006 02:44am | #1
    Most hot tubs and Jacuzzis are fed with a 240V circuit.  A 240V GFCI is required -- the regular wall outlet variety won't do it.  The GFCI may either be in the breaker panel (special GFCI double pole breaker) or in the disconnect that should be somewhere near the Jacuzzi.
    Seven blunders of the world that lead to violence: wealth without work, pleasure without conscience, knowledge without character, commerce without morality, science without humanity, worship without sacrifice, politics without principle. --Mahatma Gandhi
    1. hvac2000 | Oct 24, 2006 02:58am | #2
      Most indoor bathroom type jaccuzi's tubs are fed by a 120 volt line. This a jaccuzi style  bath tub. At least most of the one's I have seen and installed. I did not check if this is a 240 or 120 volt tub. I am to beleive it is a 120 volt jaccuzi because the wall timer breaks only one wire. Thanks Jay
        BillHartmann | Oct 24, 2006 03:37am | #3
        For something like that they often use either a deadface GFCI or a GFCI breaker.A deadface GFCI looks like a GFCI receptacle, but it does not have a receptacle on it.If it is not visable in the bathroom (or possible behind the access panel {where it should not be anyway}) then look on in the rooms that but up to this area. I have hear them found in closets.There are tone tracers that can be used on unpowered circuits to trace them.
A New Approach to Foundations
