Jamb Saw
doodabug | Posted in Tools for Home Building on June 11, 2005 10:26am
I would like comments on jamb saws.
I say it is a remodeling tool and it isn’t needed on new construction.
  1. calvin | Jun 11, 2005 10:30pm | #1
    A jamb saw is a tool.
    Quittin' Time
    BillHartmann | Jun 11, 2005 10:33pm | #2
    There are never any change order or screwups in new construction?
    1. doodabug | Jun 11, 2005 11:28pm | #3
      I guess I should rephrase my question. Unless somebody screws up or changes their mind would a jamb saw normally be used on a remodel job? I'm sorry I wasn't more specific.
      1. jayzog | Jun 11, 2005 11:35pm | #4
        I have a Crain jamb saw that is usefull enough to earn a spot in my trailer.
        I hav not seen any competitors jamb saw, but the Crain is pretty cheesy and expensive too.
        1. dIrishInMe | Jun 12, 2005 09:21am | #8
          Actually I talked to one of my flooring guys about jamb saws and he felt that Crain was one of the better ones since it is a little better at getting in the corners, etc.  Others have the blade mounted directly on the motor shaft, like a sidewinder, and don't get in the tight spots as good.
          To the original poster - yea it's needed in new construction too.  I have my finish flooring installed as late in the game as possible.  If I try to get the trim guy to install the door jambs/casings at the exact right height, it never works out right on all the doors.  Then, if there is a problem, the trim guy is long gone before it shows up (when the floor is installed).  So, I tell the trim guy to set the doors a bit lower than the thickness of the finish flooring.  I'll go around to various rooms and mark stuff like "carpet"1/2", vinyl - 0, hardwood - 1/2, etc.  This helps him to know how high to install the base too.   Then when the flooring guy shows up he cuts the jambs to the correct height - with a jamb saw.  At that point, it's his responsibility.  He will typically cut a bit of the base too.
          I would almost thing it would be needed even more in remodeling since you are always swapping out one type of flooring for another... not that I'm a remodeler.
          I have a hand jamb saw that works on something small in a pinch. Matt
      2. quicksilver | Jun 12, 2005 06:38am | #5
        A tool's a tool. No matter what. Everytime. Do you only use a recipricating saw for redo's? If it can get you there use it. Hey I know you.
        Edited 6/11/2005 11:40 pm ET by quicksilver
        1. doodabug | Jun 12, 2005 07:02pm | #9
          The only time I use a recip saw on new work is if I or somebody else made a mistake.
          1. quicksilver | Jun 12, 2005 07:29pm | #10
            Let's break the ice. I'm sure we both know how to get our jobs done. I am happy with my techniques and have been building four twenty years. That makes me 40. I learn everyday. I've pursued carpentry seriously since I began. You might feel the same about yourself. So lets let up because the next time you realize hey I could use this tool for that. I don't want you to think " I can't use that because its a remodeling tool or that's a demo tool. Abilty to be creative goes a long way in the field. So use whatever you want to do what ever you want. And lets be friends
          2. toolin | Jun 12, 2005 09:44pm | #11
            Have had some luck using a bisquit jointer and then a chisel in a pinch.
          3. quicksilver | Jun 12, 2005 10:02pm | #12
            I agree bisquit joiners are not just for breakfast anymore. We used one with a diamond blade once to cut 3/4's out of a ground face block wall so that we could start the hardwood just back from the wall plane. It gave us a good clean look.
          4. doodabug | Jun 12, 2005 10:39pm | #13
            I have been a carpenter for 27 years. I study and research my craft with a passion.
            My point of the question was how bad I would feel for making a flooring guys job harder by making him get a jamb saw out on new work. I think the point of the tool is to make a flooring guys job easier on rework. Maybe I am too old school. It is a little harder for me to set a door jamb on top of hardwood especially if floors are a little off but I think it should be done that way.
          5. quicksilver | Jun 12, 2005 10:51pm | #14
            and you're entitled to your opinion
            Edited 6/12/2005 3:51 pm ET by quicksilver
            G80104 | Jun 14, 2005 05:42am | #18
               I am with you on the jamb being on top of the floor in new construction, also hate it when cabinets go in 1st & flooring around them!
        hammer1 | Jun 12, 2005 08:34am | #7
        A jamb saw is primarily used by floor installers. I guess if you lay a lot of hardwood flooring with existing door jambs, it could be handy. I've never used one on a remodeling job but I have used a hammer and chisel, handsaw, sawzall, flush cut saw, Fein multimaster and a utility knife to accomplish the same cuts on an occasional basis.Beat it to fit / Paint it to match
        1. JasonPharez | Jun 13, 2005 05:56am | #16
          Hammer, if you've got a jig saw with a removable base (like the new Bosch I have), just remove the base, scribe the jamb using a scrap of flooring, and slap a reverse cut blade in for the finest jury-rigged jamb saw in the world!Jason Pharez Construction
             Framing & Exterior Remodeling
    JeffBuck | Jun 12, 2005 08:20am | #6
    I agree ...
    customers never change their minds in new construction.
    so being prepared for that ...
    is just ... what?
    smart, maybe?
    what'sa matter? U jealous some guy had a better stocked tool trailer than U?
        Buck Construction
     Artistry In Carpentry
         Pittsburgh Pa
    1. doodabug | Jun 12, 2005 11:05pm | #15
      I don't even have a trailer.
    Fonzie | Jun 14, 2005 05:16am | #17
    Don't need one. Use a long fine bimetal blade turned backwards on a Makita Recipricating saw and a guage on the floor up against the jamb.
Putting Drywall Sanders to the Test: Power, Precision, and Dust Control
A pro painter evaluates a variety of drywall sanders and dust collection systems for quality of finish, user fatigue, and more.
