joining steam radiator segments
varmint | Posted in Energy, Heating & Insulation on June 5, 2002 09:58am
A friend just gave me a large (17 segments) old cast iron steam radiator. We split it into two pieces to move it, and now I want to join the very last segment to the first 9, making a 10 segment radiator. It’s a low pressure, one-pipe system, with a steam vent on that last section, which should work fine, since it’s almost identical with all the other radiators on the system, but I want to know what to use to seal the joint where I am joining segments? Four rods mechanically hold the segments together, but I don’t want any leaks… Thanks, jkm101
  1. Steve_T | Jun 05, 2002 10:07pm | #1
    I don,t remember the generic name for white pipe jointing compound or 'pipe dope' in the US, in England its 'Boss white' anyhow that and hemp strands will work fine.
    Edited 6/5/2002 3:10:01 PM ET by STEVE_T
    1. varmint | Jun 07, 2002 07:05pm | #2
      Thanks- I had considered pipe dope, and I suppose a dose of dope will work... The sections have a machined sleeve on one side, and a corresponding female opening, also machined, on the other, so they make a pretty good joint as is. They were stuck together orginally with something that looks like shellac, but who knows?
      1. Stray | Jun 21, 2002 05:56pm | #3
        If you ever want to get it apart again, the pipe dope is probably your best bet (Something like Rector-seal). As long as the machining is still a good tight fit on the push nipple, that's what I'd use.
        I've also had good luck using JB-Weld (a heat resistant epoxy, check an auto supply store) on cast iron radiators, but that's permanent.
