Joining two bottom plates question?
blownonfuel | Posted in Construction Techniques on June 10, 2008 08:50am
Hello. Let’s say you have two 16′ bottom plates that you are going to butt together to make a 32′ long wall, at the butt joint does one just place a stud over the butt and toe nail the two halves together?
Are there other techniques?
    jonblakemore | Jun 10, 2008 09:05pm | #1
    The '03 IRC doesn't mandate that your butt joints are at studs. I don't have a problem with letting your joints fall where they do, you may have some problems when raising the wall but they're relatively minor.
    Jon Blakemore
    1. blownonfuel | Jun 10, 2008 09:20pm | #2
      Thanks for your help Jon.
    Ted W. | Jun 11, 2008 12:32am | #3
    Put the butt joint between studs and splice them together with a 14 1/2" piece, like a double plate just at that spot.
    Cheap Tools at MyToolbox.net
    See some of my work at TedsCarpentry.com
    1. blownonfuel | Jun 11, 2008 05:05pm | #8
      Thanks Ted I appriciate your help.
  3. frammer52 | Jun 11, 2008 01:27am | #4
    On long walls we end the plate with a stud on both plates and nail the studs together when stood.
      Dinosaur | Jun 11, 2008 03:36am | #5
      Bingo.
      Dinosaur
      jonblakemore | Jun 11, 2008 06:36am | #6
      Your method adds more material to the job (with very little benefit) and more thermal bridging.If you're concerned, why not just put a scab over the splice like Ted mentioned?
      1. frammer52 | Jun 11, 2008 04:33pm | #7
        First, it may add more thermal bridging but a wall totaly built can be heavy and quite unwieldy, this allows the wall to be built without an added safety problem.  As far as materiels are concerned, maybw 4 studs on a house?  In the building of a house, that is not much.
    3. blownonfuel | Jun 11, 2008 05:07pm | #9
      Thanks again frammer52 for your help.
