joining wood floors in 2 rooms
cutter1971 | Posted in Construction Techniques on January 17, 2010 10:38am
My house has yellow pine floors throughout. I recently moved an interior door between 2 adjoining rooms (closed in 1 and opened a new 1). Now a portion of the bottom plate needs to be cut out and the floors between the room need to be joined. The wood runs perpendicular to the door opening. What’s the best way to do this? rip up a big section of the flooring and re-install? Some kind of threshold?
  1. DanH | Jan 17, 2010 11:26pm | #1
    Yes. A good floor guy can make it look like it was meant to be that way.
  2. calvin | Jan 18, 2010 06:59am | #2
    A threshold would be way easier than toothing in new or salvaged wood in that doorway, unless of course you're refinishing the whole shebang. If refinishing you might be able to make it look like it was always there. Using the same vintage wood salvaged from perhaps a closet. If the runs in both rooms are true to each other.
    rjw | Jan 18, 2010 07:02am | #3
    I'm with Calvin - trying to
    I'm with Calvin - trying to align the boards can be a bitch - spending a lot of time and material...
    1. lifeboat | Jan 18, 2010 07:55am | #4
      You'll get more responses
      You'll get more responses over at Breaktime Classic
Picture-Perfect Pergola
