Hey guys,
I’m repairing some significant cracks in plaster walls and ceilings over button board (circa 1940). I’ve seen repairs doen with both all-purpose joint compound and patching plaster. Wanted to get some opinions?
Thanks!
Hey guys,
Thanks!
Plaster
make sure you tape the cracks.
We see alot of this button board or "Beaver" board. We use the following method to repair and it has proven superior to tape and plaster.
If the surface is chalky you have to use a masonry sealer to start after the scratching.
I am looking up at an undetectable repair that I did in 1990 on my ceiling using this method.
Scott
After removing any loose plaster and scraping out the cracks etc.
- Use plaster washers to screw any spongey areas in to the studs.
- 1st coat of Durabond. Leave low and dont waste time making pretty.
-Knock down high spots w/ your 10" knife. Do a 2nd coat w/ either Durabond or joint compoud. Pay attention here, Durabond sets like a rock, you will not be able to sand it down.
- Sand if needed. Final coat of joint compound. then sand and paint.
Many happy repairs!!
