I am building a wall at a 90 degree angle to another wall that I just painted with latex paint. Do I have to sand the paint in the corner before applying the joint compound or will it stick to the paint OK?
Thanks.
Paul
Thanks.
Paul
if the paint is flat the compound should be fine.
If its a gloss than sand it with a 220 grit paper
My life is my passion!
Shouldn't be a problem, assuming flat paint. Though you said it was "just" painted, I would clean it with TSP if there is any doubt of how clean it is.
Hope this helps. Rich.
If the paint is real fresh, joint compound may lift the paint.
