Howdy all….
I was wondering if anyone could give me the max. span for 3×6 OAK fllor joists. I’m looking at a c1730 carrige house that someone wants to put a loft in. If you have a span table for oak timbers, that would be a great help.
Howdy all….
Listeners write in about changing careers and organizing volunteer builders and ask questions about high humidity, underfloor cooling, and removing ceiling texture.
Peter -
To help you, we need more info. Primarily, what the load you are designing for (sounds like a normal 2nd flr - 10 lbs/sf dead load and 40 lbs/sf live load), and what the spacing of the floor joist is or will be. I have span tables for oak beams but need that info to give you a rough estimate. Obviously it depends on what the condition of the beams is if they are existing. The tables I have are in Tedd Benson's book, "Building the Timber Frame House".
Nick-
Sorry for leaving out some details. My computer was behaving last night. Joists are 24"oc, condition is good. Load would be as you indicated.
Thanks for the help
Peter -
According to my tables, the safe span for 50 lbs/sf uniform load would be about 10'6". I guess I ought to offer a disclaimer saying that I am not a P.E. or any type of engineer, just some guy with a book with span tables. Good luck with your project.
P.S. - this is for a deflection of 1/360th.
Nick-
Thanks for the quick help...despite you confirming my fears.
The room span is around 14ft. I guess I'll have to convince the owner that a beam, and post in the center of the room really wopuld look nice
thanks again
pm.
Howdy all....
I was wondering if anyone could give me the max. span for 3x6 OAK fllor joists. I'm looking at a c1730 carrige house that someone wants to put a loft in. If you have a span table for oak timbers, that would be a great help.
