Joist strength question
Sardog | Posted in General Discussion on August 31, 2008 02:36am
Hi all
I have a question about the strength of a floor joist.
My friend was working on a job installing floor joists.
The joists were 2×10 about 6 ft long.
He was cutting one end (notching) about 2″ to fit and the other end 3″ to fit.
I asked why he didn’t just use 2×8 joists instead.
He felt they were stronger, and I thought that the strength was the same.
No big deal, but I am curious how this works.
  1. FastEddie | Aug 31, 2008 02:40am | #1
    If he notched from the bottom, he now has a 2x7 on one end.
    MarkH | Aug 31, 2008 02:54am | #2
    I think your friend is somewhat right. Suppose he cut all but 1 1/2" off each end. Compare that to a 2x2 joist. I have to think it would be better. Well until the ends split off and the floor caved in. Which is the rub, but until the tension shears the joist, I believe it is stronger.
  3. junkhound | Aug 31, 2008 02:56am | #3
    Well, you could park 4 tons  right in the middle of that 6 ft 2x10 (#1DF or SYP) and it would not break. Aint gonna deflect much either.
    If your buddy glued a piece of 3/4 ply to each side near the notch so the 2x10 would not split (biggest strength reduction from notching) ,  you could notch that puppy down to about 4" left.  Without the split prevention ply - can't do that calc in my head or without looking up some split factors, but down to 7" should not reduce ultimate strength.
    Matt | Aug 31, 2008 02:57am | #4
    notching on the end doesn't subtract all that much from the strength.  You see it all the time when ledger strips are used - say like when joists are attached to the face of a girder.  3" is kinda excessive though.
    OTOH - with a 6' span it really doesn't matter - 2x8 or 2x10 unless there is something else going on there - like a water bed, hot tub, etc.
    1. Sardog | Aug 31, 2008 04:20am | #5
      Matt
      I have no idea what's going there.
      I do know he glues plywood decking to it normally and he's been doing this stuff for a long time.
      I guess I'll have to admit he's probably right and I'm wrong.
      1. roqqytop | Aug 31, 2008 06:21am | #6
        @ a 6 foot span the control is shear and depending upon the species of wood, the 2 x's allowable load would be somewhere around 600 plf for a 2 x 8.
        IMO he is wasting time using 2 x 10's.And of course deflection would be a non factor.
