Jotul LP Gas Stove heat output level
cocteau3 | Posted in Energy, Heating & Insulation on January 19, 2005 05:30am
I recently purchased and had installed a Jotul Allagash gas stove. We are using LP gas, and I assume the installer converted the unit from natural gas to LP using the supplied conversion kit. The problem is the stove does not put out much heat. We are using it in a 700 sf home with a one room open floor plan and live in a mild winter climate. The ceiling is only 8′ and the building is very well insulated. I had two portable electric 1500W heaters before the stove, and the stove doesn’t heat much more than those . . . do you have any feedback on installation, settings, etc. that could help us troubleshoot this problem? The information about the stove said it heats up to 1300 sf, so we considered our 700 sf house to be a perfect match for the unit. Could it be the orafice for LP gas is not correct?
    IMERC | Jan 19, 2005 05:36am | #1
    yes...
    what is the BTU rating... for both if it gives it...
    what number orface do you have left over... was the gas valve switched over too...
    where is here???
    WOW!!!   What a Ride!
    1. cocteau3 | Jan 20, 2005 01:47am | #2
      Asheville, NC is the climate.28,000 is the BTU rating.Orafice left over is #39 (manual says that one is for Natural Gas = good).Thanks!
      1. DanH | Jan 29, 2005 04:23am | #18
        In Minnesota, 28,000 BTU of OUTPUT could certainly take the chill off of 700 sq ft (reasonably well insulated), if not necessarily heat it to broil. Is the 28K input or output? What's the supposed efficiency of the unit?
        1. cocteau3 | Feb 01, 2005 03:53am | #19
          I'm pretty sure it's output, that's how Jotul rates the stoves? Efficiency is about 85%. Still haven't heard from Jotul. I'm dissapointed.
    2. cocteau3 | Jan 20, 2005 01:48am | #3
      Did you mean was the unit switched over from Natural to LP? I assume it was, since the NG orafice is left over. But, would that cause this problem if not switched over, or would that just affect flame picture?Thanks,
        IMERC | Jan 20, 2005 01:59am | #4
        the LP gas orfice has been used... we hope... if the unit is still sitting on the floor or were you installed it originally... this is good...
        now what # is that one... IIRC it should be in the 40's...
        what could be happening is not enough gas is getting to the burners.... this may be the gas vale and not the orfice...
        WOW!!!   What a Ride!
        coonass | Jan 20, 2005 02:01am | #5
        COCTEAU3,
        Check to see if the regulator has been switched to propane. There is usually a little cap that screws on with a "button" that you flip over to change from natural to propane. Natural has a bigger orifice but lower pressure. With the smaller orifice (propane) and lower pressure (regulator set to natural) you would see less BTU's.KK
    IMERC | Jan 20, 2005 09:48pm | #6
    is it calibratd for the altitude that yur at...
    what's the gas pressure at the unit...
    is the supply line undersized..
    can you hear the burners whistle as it heats or the flow of gas to burners...
    WOW!!!   What a Ride!
    IMERC | Jan 20, 2005 09:50pm | #7
    altitude is configured in 2k increments to 4k feet...
    1K increments after that to 10k....
    500' elevation changes above 10k...
    WOW!!!   What a Ride!
    1. TMO | Jan 22, 2005 05:02pm | #8
      I'm having exactly the same problem. With exactly the same stove. I'm very confident I changed all orifices and valves correctly. We added a 200sf addition with a 10 foot  opening into the room. We had hoped (since the claim was it would heat 1300sf) it would help keep the reat of the area a little warmer.
      We have been sadly disappointed.
      1. TMO | Jan 22, 2005 05:05pm | #9
        How do you check the gas pressure and calibrate it for altitude?
        1. cocteau3 | Jan 23, 2005 04:58am | #10
          TMO:My guess is that the "certified installer" has the equipment and knowhow to check the pressure without blowing up the stove . . . my installer was questionable at best, so I'm trying to contact Jotul directly to get some feedback. Does your dealer offer a tradeup in such a situation? My dealer has yet to be contacted, and when I do, I will ask for help, or ask for a size bigger. Jotul's claim of 1300sf is impossible at best. I'm going to power down the stove and check the setting for the restrictor settings but I think my flame picture is excellent. So I doubt there is a drafting problem. Our flame is about 6 inches at highest, with a good mix of blue and yellow. Your's?john
          1. TMO | Jan 24, 2005 03:38pm | #14
            Mine gets about 6" or so as well. It is super attractive and the flames look great. I hadn't really thought about going back to the dealer yet. I wasn't positive the problem is with the stove. Since you seem to be having exactly the same problem It has made me wonder.
            Did you get the blower?
          2. cocteau3 | Jan 24, 2005 09:57pm | #15
            Yes, I got the blower, cost $249 extra. It doesn't blow very well. Mostly it creates some flow up and through the top grate. I do like the automatic setting, however. Sounds like we have the same flame picture experience. I'm waiting to hear from Jotul tech (who were on vacation until today) about the output subject. Do you have any contact info for them too?
          3. TMO | Jan 25, 2005 03:10pm | #16
            No. I'd appreciate it if you could post it. Thanks in advance.
          4. RoyS | Jan 29, 2005 03:06am | #17
            Guys- I have the NG version of this stove in a 960sf house vic. Tacoma, WA (mild winters) w/ 12' ceilings in part and it does a great job of keeping us warm. I realize there is different heat output in NG vs. LP, but if we didn't have this thing hooked to a thermostat, it would cook us out of the house. We like it, but obviously you guys are having a very different experience. And my flames are probably 4", mostly blue w/ some yellow- not as decorative as the one in the store, but nice enough.
        2. cocteau3 | Jan 23, 2005 05:00am | #11
          ON page 19 of the manual, it says not to change anything for altitudes from 2000-4500 feet. I live at approx. 2100 ft. The PDF manual available on the Jotul site had suggested to convert for high altitude above 2500 ft, however, I assume the manual we got with the stove takes precedence over the PDF online manual. j.
            IMERC | Jan 23, 2005 09:30am | #13
            might want to get an official ruling from the company...
            proud member of the FOR/FOS club...
            WOW!!!   What a Ride!
          IMERC | Jan 23, 2005 09:29am | #12
          it's the back to the gas company fer the pressure check and it's the orfice size relative to altitude...
          Mfgr spec'd...
          WOW!!!   What a Ride!
Old House Air-Sealing Basics
