Juno air-ooc gaskets?
CRF | Posted in Energy, Heating & Insulation on January 19, 2008 06:52am
Has anyone ever tried the energy gaskets that are in the Juno  recessed light catalog?  The cans I have are IC “air-loc” rated and have an option an “energy conserving gasket”.  Regular trim kits are used.
Problem I found is the wholesale electrical house had never even heard of them until I showed him in the catalog, and he says “sure, I can order them”.  He couldn’t get me a price because the computer was down.
Are these things worth the money or should I try to seal the can with caulk and such?
I am in Idaho and winters can easily get way below zero, in fact the high this week hasn’t been above 12 degrees F.  New construction, and r50 blown on top off cans.
Aaron
  1. wallyo | Jan 19, 2008 09:10am | #1
    CRF
    I am in the same state geography your are in. Don't know about Juno's but Halo's airlocks come with them nothing special on the HALO just a ring 1/2" wide grey foam rubber, If that is what Juno's are that's sad that they are an option.
    Wallyo
    1. CRF | Jan 19, 2008 06:14pm | #2
      That is what I'm afraid of, spending $4? for a round piece of foam.  (Just a SWAG on the price)  There is no picture or description in the catalog.
      Hasn't anyone seen/used these?
        BillHartmann | Jan 19, 2008 06:28pm | #3
        Go to juno's website and see if they have Rep locator.Find your rep and asking him exactly what they are and see if he has a sample..
      2. wallyo | Jan 19, 2008 07:03pm | #4
        I take it you already purchased and may have installed the cans. Other wise I'd check out the Halo and consider them (unless there is one particular trim you were after that only Juno had). Is it posibable that yours where just shiped without the gaskets? if your near a lowes I think they might be carring some juno now, Grovers too check the cans at either place to see if yours are just missing the rings, If they were in bulk boxes they are usually just thrown in the box, sometimes put in each can, but could of been on top of one can and some just pulled them out.Can Juno and ask them what gives.Wallyo
        Edited 1/19/2008 11:05 am ET by wallyo
        1. CRF | Jan 20, 2008 04:26am | #6
          I have already installed the cans (actually have already sheetrocked and painted) and of the 50 some cans I bought not a single box had any sort of foam ring in there new box of six cans per box)
          If the foam trim is what they call the energy gasket then I will do what I was planning and seal the perimeter of the can and call it good.
          Just a thought, even with  the "gasket" what "seals" the air from just traveling up past the bulb and into the metal box?  Doesn't seem like the gasket is worth the trouble whatsoever.
          1. wallyo | Jan 23, 2008 09:50am | #7
            CRF The seal does go on the can and sits between it and the drywall don't know how much they help either. The can it self is double walled and it is the second wall that make it airlocked. Some trims do have there own foam ring. Fillig that gap between the sheetrock and the can lip will help.Wallyo
            Edited 1/23/2008 1:52 am ET by wallyo
          2. alwaysoverbudget | Jan 23, 2008 05:03pm | #8
            well i don't feel so stupid now,i put the foam gasket on before sheetrock ,and going by this thread thought i've been doing it all wrong. wouldn't be the first time.lol    larryif a man speaks in the forest,and there's not a woman to hear him,is he still wrong?
      3. alwaysoverbudget | Jan 19, 2008 08:49pm | #5
        they aren't any rocket science,a thin,maybe 1/16-1/8 thick foam gasket about a 1/2 wide. like someone else said mine were just laying in the box when i opened them up[box of 6?].
        i dont know how much they will save you,but reading this  shows how stupid i am. i put them on the can before the sheetrock so that it would seal at that area and my thought was doesn't matter  if you ever put trim on.i also sealed all my cans seams with silicone before they went up. i don't know where they get the term airtight at but my definition is different than theirs.then run a small bead at the sheetrock/can edge with latex.   larryif a man speaks in the forest,and there's not a woman to hear him,is he still wrong?
  • A Postwar Comeback
