KCM or MCM
Soultrain | Posted in General Discussion on February 15, 2006 08:19am
I have a long secondary extension (300 ft or so), so I am running 250KCM (3 legs, Al,  USE) for my service entrance.
When I orered it from the supplier, he didn’t know what “KCM” was, so I asked for 250 MCM (which I’ve also heard it called) & he knew what that was.  However, when I got it, the cable was labled 250KCM on the jacket – but the receipt said MCM.
The long & short of it is – why are there two names for this diameter cable & which is correct?
Regardless, it’s some heavy stuff.
    maddog3 | Feb 15, 2006 08:44pm | #1
    those of us that play with it commonly refer to it as
    ...thousandths....250thousandths...and so on .....until we get to 2000MCM.....then its simply called 2 million
    I personally don't compare the CM designations.....just as long as the stuff is the right size
    _________________
    they also print ...kcmil..... on the jackets too
    Edited 2/15/2006 12:47 pm by maddog3
  2. JohnSprung | Feb 15, 2006 11:05pm | #2
    The K comes from Kilo, which is Greek for thousand, the M is from the Latin word for thousand, IIRC, mille or milla or something like that.
    Fun, isn't it, how two ancient civilizations can still be confusing electricians after a couple thousand years?  ;-)
    -- J.S.
      Soultrain | Feb 15, 2006 11:44pm | #3
        BillHartmann | Feb 16, 2006 02:39am | #4
        While Roman Numerals are not used much anymore you will still see M and C used such as,$xx per C fasteners (per hundred)$xx per M board feet (per thousand).The Greek modifiers are used for all scientic and metric measurements. Most common, even outside thsoe areas, are k (kilo - thousand) and m (mega- millions).yotta [Y] 1 000 000 000 000 000 000 000 000 = 10^24
        zetta [Z] 1 000 000 000 000 000 000 000 = 10^21
        exa [E] 1 000 000 000 000 000 000 = 10^18
        peta [P] 1 000 000 000 000 000 = 10^15
        tera [T] 1 000 000 000 000 = 10^12
        giga [G] 1 000 000 000 (a thousand millions = a billion)
        mega [M] 1 000 000 (a million)
        kilo [k] 1 000 (a thousand)
        hecto [h] 100 (a hundred)
        deca [da]10 (ten)
        1
        deci [d] 0.1 (a tenth)
        centi [c] 0.01 (a hundredth)
        milli [m] 0.001 (a thousandth)
        micro [µ] 0.000 001 (a millionth)
        nano [n] 0.000 000 001 (a thousand millionth)
        pico [p] 0.000 000 000 001 = 10^-12
        femto [f] 0.000 000 000 000 001 = 10^-15
        atto [a] 0.000 000 000 000 000 001 = 10^-18
        zepto [z] 0.000 000 000 000 000 000 001 = 10^-21
        yocto [y] 0.000 000 000 000 000 000 000 001 = 10^-24
        1. JohnSprung | Feb 16, 2006 03:00am | #5
          There were wars between the Greeks and Romans in ancient times, and their prefixes are still here fighting it out....  ;-)
          -- J.S.
          Soultrain | Feb 16, 2006 04:09am | #6
          I know the CM stands for Circular Mils.  I just wondered about the prefixes.
          I know Kilo was 1,000, (mille being lating makes sense for the M)
          1. FrankDuVal | Feb 16, 2006 07:51am | #7
            As stated above, KCM= 1000 circular millsMCM= 1000 circular millsK is Greek for 1000M is Latin for 1000Therefore:KCM=MCMK is well known as 1000 modifier, in uses as KW for killowatts.M is also known in inventory work, price per 1000 pieces is $/M. You see this on invoice when buying wire at the electrical supply house.Frank DuVal You can never make something foolproof because fools are so ingenious.
    user-14544 | Feb 16, 2006 11:12am | #8
    seems to me your CSA is a big PITA whereas his CEO has no problem with shipping your order COD via UPS...or FED-EX....
    knowledge without experience is just information.... Mark Twain
    http://www.cobrajem.com
      Soultrain | Feb 16, 2006 05:52pm | #9
      I'm not sure what your talking about.  I just went to the my local electircal supply house.  The guy at the counter had never heard KCM before, he knew it as MCM.
      However, a couple of posters have already answered my question.
        user-14544 | Feb 17, 2006 12:17am | #10
        was just pokin' fun at the acronyms...and the fact I have no idea what you were talking about...knowledge without experience is just information.... Mark Twain
          Soultrain | Feb 17, 2006 03:25pm | #13
          I get it now.  I guess I was a little slow there...
      2. FrankDuVal | Feb 17, 2006 07:50am | #11
        You said "I just went to the my local electircal supply house. The guy at the counter had never heard KCM before, he knew it as MCM."Even better, I was at Electrical Equipment today (local supply chain) and the Thomas & Betts laminated display on the counter showing different styles of their crimp lugs had MCM in some tables and KCM in other tables! Same company, same display, I guess different departments made the charts at different times.Frank DuVal You can never make something foolproof because fools are so ingenious.
        1. wrudiger | Feb 17, 2006 08:15am | #12
          Dang, and here I always thought KCM was a BBQ sauce!
          Edited 2/17/2006 12:16 am by wrudiger
Podcast Episode 691: Replacing Vinyl Siding, Sloping Concrete, and Flat vs. Pitched Roofs
Listeners write in about ground-source heat pumps and weatherstripping and ask questions about engineered siding, concrete that slopes the wrong way, and why houses have pitched roofs.
  • A Postwar Comeback
